clear ip-security source-ip-lockdown entries ports
clear ip-security source-ip-lockdown entries ports [ ports | all ]
Description
Clears locked-down source IP addresses on a per-port basis.
Syntax Description
ports Specifies the port or ports to be cleared.
all Specifies that all ports are to be cleared.
Default
N/A.
Usage Guidelines
Use this command to clear locked-down source IP addresses on a per port basis. This command deletes the entries on the indicated ports and clears the associated ACLs.
This command was first available in ExtremeXOS 12.0.
Platform Availability
